Posted by D Slater on July 15, 2011 at 19:44:53 from (184.15.41.100):
In Reply to: power steering on 450 posted by plow hand on July 15, 2011 at 19:16:44:
If like IH did, sheet metal and fuel tank needs removed, Power steering type regulator and saftey valve installed. Power steering type hydraulic control valve. Pipe and fittings that go from regulator to control valve. Orfice plug installed between control valve and control valve support housing. Pressure and return hose and fittings. Steering unit installed with shorter worm shaft and a coupling. Also a steering unit brace. One was used on a diesel. Or a charr lynn or other aftermarket with a pump mounted to run off a belt.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
