Re: IH 966 PTO issues
Posted by Owen Aaland on July 19, 2011 at 16:34:24 from (216.47.34.189):
In Reply to: IH 966 PTO issues posted by Andi on July 19, 2011 at 06:47:06:
Do you mean you have a remote mounted, PTO driven hydraulic pump for the loader? The PTO is not remote mounted on the tractor.
It is possible that the oil pickup tube for the PTO has come out of place or the tube seal is leaking. To check it face the tractor uphill so that you have extra oil covering the PTO and see if the problem is still there. The normal full mark on the oil dip stick will put the put level at the middle of the PTO drive shaft. The pickup tube is just below the drive shaft so if the oil is a little low the seal may be above the oil level. If the tractor is facing down hill the seal and top of the tube will be above the oil level.
Another possibility is internal leaks in the PTO assembly, either the piston seal, or a worn housing where the sealing rings ride.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
