Yes, without knowing what exactly you have, nobody can tell you exactly what you need. I'm gonna assume you have a stock tractor with no 2-way valve.
It's really pretty simple once you've seen it. People always think hydraulics are this mysterious complicated thing...
To get down pressure, you need a 2-way open center hydraulic valve of some sort. Originally the tractor would be equipped with the optional 2-way "christmas tree" valve mounted on the right side behind the hydraulic block.
You can use any commercially-available 2-way open center hydraulic valve. When shopping look for one with NPT ports, so you don't have to mess with adapters. Mount the valve somewhere convenient.
There are two pressure ports on the rear of the H hydraulic block. Cap one off and run a hose from the other to the IN port on the valve. Run another hose from the OUT port on the valve to one of the drain plugs on the hydraulic block.
Run a hose from one work port on the valve to the rear of the tractor. Install a TEE fitting on the end of the hose. Run two short hoses from the TEE to the SAME END of both hydraulic cylinders.
Do the same for the other work port to the other end of the cylinders.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
