Posted by gene bender on July 21, 2011 at 11:54:57 from (207.177.56.53):
In Reply to: Is there any reason posted by Kevin W on July 21, 2011 at 11:03:03:
Adding second set of lites will cause more amp draw that your system is set for. Now if your gen is the original and you have the adjustable thrid brush you can increase the amps with no problem. You wont be using the lites all nite long anyway. You can check the gen and look for the screw head on the brush end and remove the brush cover to see how close the third brush is and adjust accordingly. Mite need to take the gen to have it serviced.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
