Posted by wfd2 on July 23, 2011 at 14:00:55 from (75.192.92.90):
I just purchased a Shaver HD-10 post driver for the back of my 656. I have two remotes on the 656. One is running my front loader and the other is open. I"m going to use the open remote for the driver.
There is a pressure line (smaller diameter hose and a bigger line (1" diameter hose) on the driver. The pressure line has a coupler on it (which may just plug into my remote), and the larger hose with just a male end with threads. I asked the guy who owned the driver before me and he said that he just put the return hose back into the hydraulic tank. I think it"s supposed to be hooked to the return side of the remote fitting.
So, a few questions if I may...
1. Can I just screw on the fitting for my tractor on the return hose and simply hook it up to the remote?
2. The remote has two inputs, and for the lack of my experience, I"m calling them an upper and a lower coupling in the same remote. I"m assuming that the upper coupling is the pressure side (because on my loader remote, the single pressure line is looked into the upper coupler) and the lower is the return. Is this correct on the 656?
3. The driver has not been used for about 5 years, but it was stored inside and it still in really good condition. After I hook the driver up to the tractor and exercise it (before pounding posts), I will have to check my hydraulic fluid in the tractor, right? The tractor"s hydraulic fluid will fill the pounder hydraulics, right? Also, is there any trick to bleeding the lines if it is needed?
4. And finally, your opinion on using the Shaver HD-10 driver on the 656... this tractor is capable of running this driver, right?
As you all probably know, using the pounder can be extremely dangerous. I just want to make sure mechanically, the tractor can handle this pounder and I connect it correctly. Any usage tips are also much appreciated!
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
