Posted by P and R Pete on July 26, 2011 at 15:18:19 from (173.86.33.60):
In Reply to: Need Help! posted by Livin the Dream on July 26, 2011 at 04:32:59:
Every time the piston comes up, it will either be the exhaust stroke or the compression stroke.
On the exhaust stroke, the exhaust valve will be open, and you will thus feel no pressure at the spark plug hole.
On the compression stroke, both valves will be closed, thus all the air must come out the plug hole, and you will FEEL that pressure as the engine is turned, assuring you that you are getting to TDC on the correct stroke for the spark.
TDC on that correct stroke can be found via Mr. Nicholson"s method.
Re: feeling the pressure... I used a circle of inner-tube rubber big enough that it wouldn"t fall through the plug hole, and put my finger over it to make a reasonable seal. It was obvious when I was on the compression stroke.
If you feel no pressure on either stroke, then you have other problems.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
