Re: Carter UT
Posted by karl f on July 30, 2011 at 21:40:16 from (172.162.50.203):
In Reply to: Carter UT posted by Livin the Dream on July 30, 2011 at 04:06:28:
The only mixture screw on that carb is your
idle mixture. It has a fixed main jet orifice
instead of an adjustable jet.
3 turns is usually for a main jet, but only as a
starting point.
Idle screws are typically between 1 and 2 turns
as a starting point and your final adjustment
could be 1/2 or 3 turns.
Like the other poster said, there is also a screw
for your idle speed near the throttle shaft.
remember, carb adjustments vary greatly from
the initial number of turns mentioned in the
book for installation.
good luck
karl f
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
