Well looks like I figured out what was wrong with the tractor getting spark at the coil wire. I looked at everything and tried everything....even a brand new 12 volt coil. Then I noticed what I had been questioning the whole time! Someone had used their own screw (with a slotted head) for the terminal stud on the side of the distributor with no grommets to keep from grounding out except a peice of brittle plastic on the outside. I went up to a parts 140 we have, and robbed the whole stud including the nuts, washers, and grommets; then installed it on the 130 distributor.....and SHAZAM!! The coil started firing!
I began to start it over using very little ether to get it to fire since its been a good while since its ran. It started to fire but not so well. I replaced the plugs at this point because they were shot. I had some I just took out of a Super A that are pretty good, but not new. The Super A ran fine with them. After that it still fires, but it just doesn't sound right. It almost started once with us, but not quite. Its either the carburetor, or the timing might be a little off. Either way, it'll have to wait because it got dark on me and I couldn't see 2 inches in front of my eyes! hahaha.
I'm so proud I figured out that mystery though! May it be a good tip to all of you who run across this problem. Connections mean everything!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
