Re: Cub Coffee Grinder Rear End?
Posted by JRSutton on August 02, 2011 at 05:11:34 from (75.130.109.233):
In Reply to: Cub Coffee Grinder Rear End? posted by Moondoggie on August 01, 2011 at 18:49:13:
I'm not familiar with exactly what's involved in that whole procedure on the cub, but I can tell you with some certainty that any time you take any old piece of equipment apart that relies on gears, tractor or otherwise - unless you put each gear back together exactly as they were originally, meaning matching tooth to tooth how they originally meshed (which in most cases is too difficult to even try to do), you're likely to have a lot of noise for a while, until they wear in.
Hard to say what's normal without hearing it.
But if it sounds like there's a wrench in there, that might be a little more than regular reasembly noise. It's hard to say
If you're talking bevel gears, the problem gets worse if you don't re-assemble them to the exact same depth in relation to eachother. Ring and pinion gears are even more sensitive.
In most cases, if things run as they're supposed to, that's what counts, and the noise will usually go away over time.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
