Posted by rustred on August 02, 2011 at 08:32:30 from (74.200.18.156):
In Reply to: Re: F20 help please posted by elroysdad on August 02, 2011 at 07:27:47:
i believe your correct on the gears. carb setting to start with, main jet 2 1/2 turns out. idle mixture 1 1/2 turn out. this screw is out for lean and in for rich. have mag bolted to base. get #1 on compression. line up timing mark to TDC. raise breaker housing to retard spark and remove it.lift timing hook to make impuse coupling in operatable.remove dist cap.rotate mag by coupling clockwise as from coupling end. rotate till the brush is coming into alignment with cap terminal #1.just as pionts are opening you are now in time. you can put a piece of paper between points to feel when they open. just as paper pulls out you are timed. without moving a thing put the 2 bolts in the coupling where they line up directly across from each other. replace cap and cover. to check yourself crank engine over on #1 compression and check points , just as they are opening the timing marks should be in line. release timing hook and start tractor. as for compression i would say 80-90 psi.it will run good.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
