Re: 504 stops running
Posted by Janicholson on August 04, 2011 at 20:14:55 from (67.72.98.45):
In Reply to: Re: 504 stops running posted by cjmal on August 03, 2011 at 17:14:26:
A hot coil is a bad coil. They can be hot from engine heat and running behind the radiator, but they should never be hotter than the housing of the distributor where it mounts. The polarity of the coil matches the polarity of the battery. If negative ground, the coil negative is hooked to the distributor. Hooking it wrong will not hurt it or cause heat, it might not run as well for a variety of spark at the plug reasons, but no damage. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
