I the H thermosyphon or water pump? If thermosyphon, there is a simple answer: the thermosyphon works on gravity. If the nose is pointed down hill, the openings to the radiator are in the front, so the hotter coolant will be trapped at the rear of the engine to a certain degree, and hence you see the temp rise. Once you level out or go uphill, the coolant can circulate through the opens as designed. since you are rarely in a down-hill position for extended periods of time, I would not worry about it.
If you have a water pump and thermostat, then I am a bit perplexed.
my opinion.......
ps. just re-read your post, and saw you have a water pump. so, I'll let the above in place, but it doesn't apply to you situation.
This post was edited by Tom Fleming at 02:27:22 08/06/11.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
