Probably not much difference in total effect, but the larger tires will croud the furrow. In either case the plow is OK for the tractor. With it in the ground, all colters should cut 14" wide strips. Adjust the furrow wheel to make this happen. Depth should be equal on all bottoms, and the colters cutting to the left of the frog some but not more than 5/8" Check the landslides to be sure they are not woen such that the plow pulls crooked. (tapering to the rear of each is not desirable). I would use the smaller tires, as plowing is not done with wet ground. The traction will be fine. Used or new windshield wasser fluid, or Rimguard (beet juice) will not rot the rims, and is a good ides. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
