Posted by Owen Aaland on August 10, 2011 at 20:53:10 from (216.47.33.65):
In Reply to: 1486 questions posted by GRB54 on August 10, 2011 at 19:34:41:
The SMV signs have been coming off those tractors since they were new. The best solution may be just to put a metal one on just behind the one on the tank.
If you want to try again to get one to stick to the tank try this method. Completely fill the fuel tank. Park the tractor so the tank faces the sun to get it warm. The fuel load also helps to expand the tank. If you put it on a cold tank when the tank warms up and expands it can cause the SMV sign to start peeling off.
Clean the area as best you can. I like to use Brake Cleaner because it will remove any fuel residue left on the tank. Sand the tank to get it smooth and help get it clean. Flush the area with brake cleaner and when it has evaporated, install the SMV sign. If the gods are smiling on you it may stay on for a while.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
