Re: IH UC-263 power unit fuel pump
Posted by Bob on August 11, 2011 at 11:29:20 from (64.255.159.192):
In Reply to: IH UC-263 power unit fuel pump posted by BFM on August 11, 2011 at 10:48:29:
I would suspect a fuel pump for a 60's or 70's 6 cyl small displacement IH truck engine would bolt right on, but some plumbing changes MIGHT be needed. If you decide to try that, make SURE the lever arm shape and travel match the old one!
Or, you might try contacting Cardone Rebuilders for a participating reseller in your area... they (used to anyway) have a rebuild and return program for obsolete pumps, etc., or perhaps they can come up with an off-the-shelf pump for you.
(BTW, have you considered simply installing an electric pump?)
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
