Re: 826 Hydro with no reverse
Posted by Owen Aaland on August 14, 2011 at 17:10:31 from (216.47.33.65):
In Reply to: 826 Hydro with no reverse posted by Centaur Nut on August 14, 2011 at 14:13:13:
With the cap on the valve it is centered in the center section. It uses hydraulic pressure to move it either in or out. If you can't pull it out is is only moving one way.
A leaking charge pressure check valve can also allow the closed loop oil to escape in one direction only. You could try swapping the check valves and see it that will change the direction in which the tractor will move.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
