The adjustment is important as well. The feel of a feeler gauge is critical. The tension on the feeler as it is pulled out from between the tip of the valve, and the rocker arm has two components, the first is the flatness of the gauge between the surfaces. such that the blade is ferr to find the least thickness, pinched gently, not at some non flat angle. The second is the tension as it is pushed and pulled through the gap. If you pinched a 1 foot steel shop ruler between your fingers hard enough to pick it up and have it dangle from one end, that tension is the same as the push pull feel on the blade. The tip of the rocker arm is often cup shaped and worn from pushing and sliding on the valve. If it is cup shaped and the gauge blade cannot be flat across the surface, the rocker tips will need to be arced on a valve machining tool. Usually they are OK, but I have seen tips with .008 wear that prevents clean adjustment. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
