Posted by Janicholson on August 15, 2011 at 14:43:47 from (199.17.6.77):
In Reply to: clucth torque adjust posted by tom levandoski on August 15, 2011 at 14:30:51:
Tom, I assume you mean the Torque Amplifier. There are three clutches in the tractor. A master clutch that is on the Flywheel, a TA clutch in the front of the TA unit, and behind the Master clutch, and finally a One way "sprague clutch" on the rear of the TA unit. Any of these can slip. If the tractor slips its engine speed to ground speed in direct, or TA reduction, and if it has gradually gotten worse, it is probably a master clutch. If the slippage occurs only in direct (TA forward) and when it slips it seems to still pull as though it was in TA reduction, It is probably the TA clutch. If it only slips when the TA is back, Reduction, and when it does it seems to just go into neutral instantly, or sometimes won't go into TA, just seems as though it is in neutral, it is the One Way clutch. All of them require a split of the tractor, and (if it were mine) I would replace them all as well as their throughout bearings and pressure plates.(not on the One Way, it has none) Hy Capacity company has quality parts. As does Kevin Meier Who frequents this site. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
