The 1953 Super M manual refers to both systems as Liftall. One is the transmission-driven Liftall (i.e. belly pump) and the other is the distributor-driven Liftall (i.e. live hydraulics).
We just call them "belly pump" and "live hydraulics" around here... No need to get so technical...
But yeah, in a nutshell, the stock live system worked exactly the same as the original belly pump: One-way hydraulics.
The main difference is you don't lose pressure when you push the clutch pedal. Adding two-way hydraulics is basically the same as on the belly pump... You need an open-center valve bank, with the OUT plumbed to one of the plugs in the rear of the block, and the IN plumbed to one of the pressure outlets in the casting that protrudes from the rear of the block.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
