Re: Well, it's unmanly, but ...
Posted by steve_in_MO on August 17, 2011 at 10:55:31 from (168.166.54.11):
In Reply to: Re: Well, it's unmanly, but ... posted by Dean Olson on August 16, 2011 at 14:44:14:
I always read those manuals, back on the day, so you're not alone. Most any old-timer like myself could show you how to set up a plow but it's kind of visual.
In words, you would start by putting the left rear tractor wheel up on a seven inch block, then drop the plow and crank away on the adjustments until the botom edges of the plow lays are flat on the ground. Then you would put both tractor wheels back on the ground and move the right rear tractor wheel in or out until both moldboards turn the same width of soil. Putting it another way, the lateral distance from the inside of the right rear tire to the front of the right lay is about the same as the lateral distance from the front of the front lay to the front of the next lay.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
