Posted by Janicholson on August 21, 2011 at 08:47:35 from (199.17.6.66):
In Reply to: Re: manifold problems posted by JR FRYE on August 21, 2011 at 07:36:31:
Nope, the stress on the pipe is heavy enough to wiggle it loose. If you clean it up with an abrasive disk on a 4" hand held grinder, it can be tapped as I indicated earlier. If you are careful, it will even look good. The threads rust between the pipe and the cast iron of the manifold. as they deteriorate, the strength goes away. One of the most prevalent and destructive factors is that water flows down the exhaust pipe i=on the outside and enters the engine through the bad fit of pipe to manifold. Because the tap cost so much, it is often passed by, and some coupling is welded on. (usually with 6011 plain steel rod. That can never work.) The tapered pipe threads are easily tapped deeper into the manifold. If you can t clean it up enough to tap, having a Nirod welded coupling put on it professionally, allows the visible part of the pipe to be replaced as needed. Been there many times, Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
