Too bad when you had the lower housing off you didnt know about the nickle sized holes at the bottom of the sleeves. These holes get plugged over time nd bad water therefore the thermo system can do its job.Every engine that i have replaced the sleeves those holes are usually plugged and not uncommon to find junk piled pretty deep around the bottom of the sleeve. Mite want to fill the system with vinegar and let set a few days then drain and back flush thru the drain to remove as much crud as you can. It would be better even if you had the radiator removed so you could use compressed air also. The temp in the coolant will run around 170 after use at the top of the radiator.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
