Posted by farmall400 on August 29, 2011 at 04:37:43 from (67.142.164.35):
In Reply to: adjust touch controls posted by realolman on August 29, 2011 at 03:22:57:
Sounds like you might have double acting cylinders and your valves set for single acting or single acting on double setting.Take the rt hood panel off and look at valve ther is a pin pointing to a d or s on each valve section it is crossways on a shaft with flats so you can put a wrench on it and switch back and forth. we had to do it every year when we put the picker on and off. If that is set to match your cylinders you have a detent problem inside the valve. hope that helps. Scottz
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
