Glenster is correct! The timing cover stays put the seal goes in from the front. The old seal can be removed with a slide hammer and flat hook, or sheet metal screws driven a little ways into the seal metal. Work it out from each side, not from one side only. The speedy sleeve is a thin metal ring that slides onto the pully machined surface to cover the groove made by the old seal. NAPA, and places like Motion Industries have them to fit, Take the pulley and old seal. It is also possible to purchase a seal that has a different thickness or lip location such that the seal rides in a different location on the pulley shank. Some of the pulleys come off with more than 4000 pounds of force. A stout splitter, or "U" placed behind the pulley is mandatory or the pulley will break. The shaft is a press fit, and can be polished some befor replacement to allow an easier install, but still a real press fit. not hand loose. It is retained by this friction. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
