Re: B rearend whine
Posted by chevy_cowboy on August 30, 2011 at 01:04:13 from (75.129.241.75):
In Reply to: B rearend whine posted by chevy_cowboy on August 28, 2011 at 09:22:11:
Ok I drained the tranny tonight and started taking the pans off the final drives to clean them and change the oil...
Got the left side pan off and noticed right away that the bull gear will move side to side maybe 1/4" or a bit more. Is that normal or is something worn out?
I tried the prybar trick on the wheel to see if it was the bearings, but nothing there moved. Also pulled the cap off the inside of the axle and that bearing looks good from the outside, no wobble their either, just the bull gear moves.
We also jacked up each side and spun the wheels to listen for where the noise was coming from... I thought originally it was the left axle housing, but it makes the same noise by spinning both wheels, and I'm pretty sure the whine is coming from the trans/diff area. I flushed those out with kerosene and gonna pop the trans cover off tomorrow to see what I can see inside.
JRSutton, you're right that the previous owner had WAY overfilled the trans, and the final drives... but even if that solved the leaks, the tractor has no brake at all on the right side (somethings broke loose inside I think) and the left is so oil soaked it's not doing much... so at the very least we need to pull it apart to clean and fix those things, I figured I might as well replace all 4 seals at the same time to protect the new brakes.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
