there is an extra hole in most of the oil filter housings that has a plug you can remove and plumb a line up to the valve cover. If not just put a tee before guage and run line from there. I have seen lines go in where the oilers were or holes drilled in cover. Have seen some with shutoffs some just lines running oil full time. Depends how well it seals up I guess. I think the only limit on head milling is when you run out of material between the water passages.If those pistons are 8000ft also they will stick up about .300" above the deck. Might want to do some math, don't want your compression too high with a mag, timing curve issues. Plus the higher the compression the higher the voltage required to fire the plug.That being said, that combustion chamber is huge. A Heisler head used a combustion chamber that was approx .300" lower than the IH head .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
