If you decide to check for a good spark like mentioned above, take off the desired plug wire FROM the Spark Plug, and hold the end of the wire to a GOOD ground on the tractor somewhere. Usually the bolt that holds on the coil. If you hold it close to a good ground, you should have a good spark. If not, check ignition components.
After reading your posts, it does sound like a gunked up carburetor. Be careful with the float becuase it is "bent" and adjusted to a certain point. When you take it apart, shake the float around and see if any gas is trapped inside. If so, its time for a new one....unless you find the hole and can solder it closed.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
