Posted by Janicholson on September 03, 2011 at 21:09:41 from (67.72.98.45):
In Reply to: Re: idle speed on H posted by c1802362 on September 03, 2011 at 18:56:00:
One on the distributor lead at the coil or distributor, the other ground. The Voltage makes no difference, unless yours is different than most. Set to 4 cyl, or 1/2 8 cyl reading. The low idle speed should be in the area of 500 to 600 RPM. they do not have much power at idle. They should run well though. As indicated below, tweak the two screws to get it right. Make sure the timing is correct, or it will not idle well. The timing advance must also work! Unless it has a mag, then the idle can be a bit lumpy, and the timing be correct. They have no centrifugal advance and once started are at full advance. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
