Posted by TMonton on September 04, 2011 at 09:10:27 from (76.214.110.48):
I have IH D-10 carburetor on a '45 Farmall H that was a mess.
I have just cleaned and put a rebuild kit into it. Ironically the kit came without any instruction and am playing off the IH manual. I am real close to a startup once I change oil, filter and ignition stuff. Non-magneto.
An out-of-box first time adjustment as I remember is as follows:
Low idle ... is a no brain'er.... makes it idle nicely.
Top Jet (closest to the manifold) is the idle air mix. Bottom out the needle and back off to 1-1/2 turns.
Bottom Jet (base of the float bowl) is the high speed mix. Bottom out the needle and back off 2-1/2 to 3 turns.
Fine tuning would be under load and tweek the high speed mix so not to run too wet but still not stray too far away from your start point.
I know that these carb's are fairly forgiving for a first time run. I just want to assure myself I am still working within basic specification.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
