Posted by Bob M on September 05, 2011 at 08:08:25 from (69.207.87.100):
In Reply to: amp meter questions posted by charlie M on September 05, 2011 at 07:31:53:
Charlie - A couple possibilities:
1 - If you can "tap" the ammeter needle to any position is says the new ammeter is defective (ie. the movement is sticking). A good ammeter will center itself at O almost instantly with no current flowing.
2 - If the ammeter deflects either direction when you make the battery connection you've got current draw somewhere. Could be as simple as the light switch left on. However a bad alternator (failed diode or regulator) will also do it. Also a short somewhere in the wiring.
Note also: If the needle defects to the + (charge) side when you connect the battery, is means the connections to the ammeter are reversed. Solution is to swap the wiring at the two ammeter posts.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
