I went out and started the tractor up and ran at 3/4 throttle. With everything hooked up (no wires removed), I hooked a jumper wire with alligator clips to the FEILD terminal on the generator, and the other end to the upper generator bracket for a ground. When I did the ammeter jumped up to around 10-11 on the charging (+) side. We thought maybe it was a ground issue. I unhooked the left screw that holds the regulator on, and scratched the surface well with a screwdriver and replaced it. Still no change. It charges only with jumper wire. Then I decided to replace the regulator with a brand new one I had on hand. After replacing the regulator, stil lthe same thing. It only charges with the jumper wire.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
