Posted by Stevishere on September 05, 2011 at 16:35:29 from (24.56.222.202):
I have a vertical distributor on my Farmall H. I installed an electronic ignition. When I first had installed the new electronic ignition, it was a little harder to start than before but it runs great!
It used to be just touch the starter and it would fire after about 1/4 revolution.
I loosened the clamp bolts and futzed with the distributor while it was running, made sure I could dump full throttle without any pops.
I would like to make certain the timing is set correctly. I found the (2) registration marks on the fan pully, hooked up my timing light, and I could see the mark, firing about 1" before the register.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
