Posted by Janicholson on September 06, 2011 at 09:45:47 from (199.17.6.77):
In Reply to: leaking H posted by Farmallb on September 06, 2011 at 09:02:04:
Three fluids can be found in that location, Trans oil (90wt gear oil) Hydraulic fluid from the belly pump (hytran, or 30 wt non detergent engine oil, or Engine oil. The ear main is the most trouble, as the engine must be removed (tractor split) to repair it. The trans leak is nex troublesom as the Liftall must be removed, then laying under it either the clutch shaft and top trans seal (input shaft) or the pump drive seal on the counter shaft need to be replaced. The Liftall is easiest as It can be removed (carefully lowered on threaded rods where the original bolts were) and repaired out from under the tractor. Best of luck hoping it is the Liftall. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
