Posted by Owen Aaland on September 06, 2011 at 13:12:29 from (216.47.32.147):
In Reply to: spark plugs for a M posted by kennell on September 06, 2011 at 05:33:35:
The Champion D16 plug was replaced by the D15Y as the recommended plug for normal use about 50 years ago. The D15Y is one heat range colder but it is an extended tip so it worked a little better. When the leaded fuels were phased out Champion changed the recommendation to D18Y for normal service but kept the D15Y for severe duty. For light duty you can use a D21 plug. That plug will help if you have an engine that burns some oil. You should not use the D21 if your tractor is going to be run for any length of time under full load like plowing. If you have trouble with fouling plugs under heavy loads you really need to address the oil/fuel problems.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
