If its the cage the main clutch release bearing rides on its thicker than it looks from the front. Has a o ring squeezed between it and the main housing on the OD. Use a slide hammer or long rod with something heavy on it in the threaded hole in the front of the clutch shaft. Its 3/8 coarse thread, both shafts and the housing will come out. If the cover is off on top of the main housing, sometimes a bar can be carefully put behind the pto drive gear and the shaft pushed forward. Warning don't get the bar on the edges of the gear teeth as they're easily chipped. Learned that the hard way the first one I tried. I have a good cage if needed.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
