ya never know what you will find in a motor
Posted by NoNewParts on September 07, 2011 at 19:08:39 from (67.240.146.222):
44 Farmall BN
bought it at just over scrap price
PO was actually using it.
ran rough
got it home and re-timed the mag and rotor.(rotor gear was off some)
now ran pretty good, smoked some
NO unusual engine noises, oil was dirty but clear, no water
tore it down to find the oiling problem, figured stuck rings,
lots of evidence it sat a long time, rust scars on the valve train, etc
started pulling pistons, no ridge to speak of.
pulled 4 then 3, sleeves looked pretty good, rings free
couldn't get #2 out....pulled #1 and went back to #2.
thought the oil ring was hanging up, so pushed it back down and took off the oil ring from below, still no go.
got it up JUST far enough to pull the wrist pin, piston came right out,
took the rod out from the bottom, bent badly.
It actually notched the sleeve, when the PO was running it.
piston, pin, pin bushing, and rod bearing are all fine.
remember, engine ran fine with no noises. go figure
Sleeve notch is 1 inch high putting it above the oil ring on the downstroke,
hence the smoke. no block damage or water leaks
(I'll be able to check better when I get the sleeve out)
so, anybody got one good rod they can spare for a fair price?
44 BN serial # 103***
rod numbers- 30926DD other side F-4 WI
third party image
third party image
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
