Re: Clutch acting strange...Help
Posted by Janicholson on September 09, 2011 at 14:34:07 from (199.17.6.77):
In Reply to: Re: Clutch acting strange...Help posted by Goodman on September 09, 2011 at 09:05:37:
You are correct (if you looked at it at all, the wrong way hits the bolts.)
On assembly it is possible to get the engine off enough to bend the hub of the clutch. If it is bent, the disk drags. Fixing requires it to be removed and straightened so it has less than .005" runout.
If the splines on the Clutch shaft are worn, or the disk hub to shaft fit is tight, it will drag.
Adjustment will not help either. If the fingers are withing .005" in height when the clutch pedal is released, they are OK. Best of luck, Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
