Thereare two issues that are very important!!!!! 1} The PTO is going to run at the same overdrive, you would need to either not use it, or use a shaft tach to determine the throttle detting for 540rpm. Not much power at less then 1/2 throttle. 2} The Belly pump Liftall (if it has one) must be disconnected and not used because of that same overdriven gear set. If converted, or is a stage II tractor, it will have an engine driven Hydraulic pump on the engine in fromt of the distributor. If so no issue there, it will work correctly. (pto still wrong in OD) Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
