Posted by pete 23 on September 14, 2011 at 12:54:35 from (74.32.234.149):
In Reply to: water pump posted by Smta on September 14, 2011 at 12:33:46:
It has a packing behind that nut with all the notches. It can be tightened but you will need a spanner wrench or devise some method. Problem if it is leaking a lot the bushings may be worn bad on impeller. If you grab hold of the impeller drive and can move it side to side tightening will not do much good. Also, you have grease fitting, one on impeller, on for ball bearings in hub. A shot or two of grease will often times stop a leak for a while.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
