Posted by Indiana Ken on September 14, 2011 at 17:11:52 from (66.249.235.212):
In Reply to: Tire inflation posted by Shawn Osborn on September 14, 2011 at 09:43:19:
For fluid filled tires the pressure should be checked with the valve stem at the top, to eliminate/minimize the effect of the fluid on the pressure reading.
A column of water 2.31 feet high equals a pressure of 1 Psi. Therefore, if the valve stem is at the bottom, the pressure gage will read the air pressure plus the fluid head pressure. Water weights 8.33 Lbs/Gal and in the case of calcium chloride solutions the additional solution weight also needs to be accounted for. For example, with the valve stem at the bottom and checking a 38" tire filled to the top of the rim with a calcium chloride solution weighting 13 Lbs/Gal the fluid head pressure will be: [38In/12In/Foot] divide [2.31 Foot/Psi] times [13Lbs/Gal/8.33Lbs/Gal] = 2.1 Psi.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
