Which style self adjuster do you have , I think first 856 had same as 806, on that style the wear inside housing can make them adjust up too tight. I have ground off ends of adjusters to get more clearance on discs. (memory not 100% on that). Have to make sure the screw operates freely and spring on adjuster is ratcheting properly. Also the return springs have to be in good shape. On the tube type adjusters, each one has to be reset and spring checked to make sure it will move plate back after aplication. In any case, you no doubt have a lot of worn uneven surfaces on drum and plates, ideally you machine all parts and measure up to obtain correct clearances. Jack up wheel and it should turn freely after releasing the brake on these dry style brakes and have like .030 clearance between discs. .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
