Posted by matt_in_michigan on September 17, 2011 at 12:03:22 from (208.53.122.83):
I just had my carb and distributor redone, and after replacing, can't get 'er to fire up.
Is there a timing mark on the crankshaft pulley, or another one perhaps somewhere that doesn't involve me having to pull the hood and radiator to see the crankshaft pulley? Or any other tip that will make it easier to set the timing? I tried pulling plug 1, and using a wire to gauge the height, but that didn't do anything for me.
I found this tip on the ssb forum, and this makes sense to me, but I wanted to check with some more experienced hands if it will work.
"In other words , rotate dist until points are closed, then rotate dist opposite direction of shaft rotation until point just start to open and rotor pointing to number one. If it is not at number one on the cap, just call that spot number one and go with firing order counter clockwise around cap."
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
