Posted by Janicholson on September 19, 2011 at 19:08:56 from (96.24.99.126):
In Reply to: Brake-Actuating Assembly posted by 1952 Farmall Super M on September 19, 2011 at 18:37:22:
Ebay, Most salvage yards, or Bates Equipment in Indiana. Many others, shop. The key is to get the stack of the expander and disks to measure .040" to .050" less than the outer case to inner surface distance when the expander is fully relaxed (balls in the lowest depth) This will require machining of the outer housing mount surface, and careful measurement with a caliper, not a ruler. The balls/ramps should be lubricated with a dry teflon (PTFE)based spray, the same for the splines. The pivot points of the links can stand a touch of the same material. TRI-Flow is one brand. A 200 grit cleanup of the friction surfaces also allows them to break in easily. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
