Posted by NC JEFF on September 24, 2011 at 05:24:32 from (50.55.241.70):
Very original tractor with orig wiring that looks good. 6 volt gen cutout relay and 6 v pos ground. sanded all connections motor tested gen good cut out good voltage on both sides of ammeter took light switch box apart and off of frame to sand for good ground. ammeter shows discharge when non running and turn on lights shows charging when running on high setting with needle two clicks below 10a voltmeter shows 6.6 at battery. when running and i remove battery neg cable from batt the tractor starts to die and the current will jump between the two and shock you like elec fence. does tractor have to have batt to run or what is going on? also what is the little flat piece on the bottom of the light switch that has shiny alum colored metal wrapped around it? do i need 7.2 to charge?
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
