The basic difference between the different sizes (414, 436, 466) is the stroke. They use different crankshafts and pistons. The main difference between the truck and tractors is they way they mount so they may have different front and rear plates, exhaust manifolds, oil pan and pickup tube, crankshaft pulley. There are also differences between different tractor engines as changes between turbocharged and naturally aspirated. Parts such as the amount of cooling jets for the pistons, water pumps, cylinder heads, pistons, rings, oil pumps, were all kind of mix and match depending where the engine was used. There were also changes made during the production runs of tractors as the engines were updated to newer designs. The result is that almost all the parts in the engines were changed from the original design to what is being made today.
As major changes were made to the engines the series number was advanced. In tractors the original designs would be the A series. The B and later series can be identified by the size stamp on the block by the serial number. The 466 B series is stamped DTT467, the C series DTT468. The same applies to the smaller engines.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
