Posted by Jim Becker on September 26, 2011 at 18:59:35 from (173.57.144.251):
In Reply to: super a belt pto seal posted by werowance on September 26, 2011 at 18:44:35:
From the factory, there was a sleeve for the seal to ride on. It was much heavier than a repair sleeve. The sleeve was normally held in place by the pulley. When the pulley was removed, there was another sleeve/spacer that went on the shaft in place of the pulley to hold the sleeve.
Not sure if you need to remove the seal retainer to change the seal, but it is probably easiest if you do.
All the Woods pulleys I have removed had a tapered hub. Take the hub retaining cap screws out and screw them into the other (threaded) holes and the pulley pops right off.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
