The exact oil pressure is not the problem. It is a change from the normal pressure that is. A chevy six with dippers on rods had 14 psi max. An H farmall will run about 70 psi max. So, if the H only puts out 14 psi you have a problem, chevy six was fine. If you have the aluminum oil filter base I suspect the pressure relief valve is shot. Easy fix. They originally had a fiber wafer and it erodes and leaks pressure. Might be oil pump end plate if valve is good. After that, think bearings, but if it holds forty psi at higher speeds it will not cause a problem.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
