I've got an American Bosch mag from a 40's era Waukesha power unit with a similar "window" on one side of the cap.
Directly behind the window is the rotor drive gear. One rotor gear tooth is painted white. When the mag is at TDC #1, the white tooth is centered in the window.
This feature simplifies timing the mag to the engine - no messing with the impulse coupling is required. With the engine at TDC #1 cyl firing, simply rotate the coupling backward until the white tooth appears, then mount the mag.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
