That improves the value quite a bit, but the problem could be as simple as an ignition/carburetor tuneup, or it could be major problems like valves.
See if they will let you run a compression check. If the compression is good and consistent across all four cylinders, you should be able to get it running right with some minor work.
$800 to $1200 sounds about right depending on the tires... They "hold air" but are they usable?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
