I am making a Super A hybrid using a lot of 140 parts. The 140 block is different. The crankshaft is different. The sleeves are different.
What I can tell about the 140 block is that it has mounting holes for a water pump and fan assembly that the Super A blocks don't have. The rockshaft lift arms look identical except that the rockshaft arm on the 140 that had a helper spring had a larger diameter hole to accommodate the helper spring than the Super A had. The thread diameter for some of the mounting brackets on the side of the bellhousing and transmission is larger on the 140 than Super A.
The crank pulley on a 140 is different than a Super A. The crank is different from a 140 and a Super A. A 140 crank can be used for a Super A, but a Super A crank cannot be used for a 140. The 140 crank is threaded, if you cut the threaded part off it can be used for a Super A pulley. I have been scolded for doing that to the crank, but it worked. The cam is identical. The 140 fuel tank will mount on a Super A, but is taller.
This post was edited by GRAPE-DRANK at 15:19:45 09/28/11 2 times.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
